28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Rendering Curved Surfaces
Is there a way to make rendering maps NOT go in the wrong direction on curved surfaces as in the attached jpg?
My only solution is not one you'll like.. make a material (material a rotated) witht the material map rotated 90deg and apply it to that part of the geometry.
There's probably a better way.. I just don't know it =(
That's not a bad idea. There area limited number of curved surfaces. The part that is nutty is that the curved surfaces behave correctly in "surface pattenr", see atached. Somethimes Revit feels like a work in progress, lo these many years.
The idea works where the materials are separated into "curves" and "straights". Bad results where there is a straight line and curve all in one solid. See attached. A Revit based solution is needed. But good try by you, I used it as much as possible.
The only other option I can give is to make an in-place family that is extruded to the same sahape as the roof, apply the material to the new in-place family which should work correctly since it is a single geometry and not multiple geometries joined together.
GL
how to create parametric double curved surfaces!!!! |
Fri, May 21, 2004 at 7:20:48 AM
Angular surfaces |
Fri, Oct 16, 2009 at 2:23:30 PM
Revit 2014 . rendering in cloud . painted surfaces |
Mon, Feb 23, 2015 at 4:13:00 PM
double curved elements |
Fri, May 21, 2004 at 7:19:41 AM
Turning floor surfaces off for individual floor elements? |
Thu, Jun 29, 2006 at 1:31:20 AM
