Forums >> Revit Building >> Technical Support >> Wall Detail
Tue, Jul 18, 2006 at 1:47:27 AM | Wall Detail
A5Len
I have a situation where the detail of a wall dissapears when the wall is given a unconnected hieght - the detail (lines defining finish thicknes & cut pattern) dissapears when the unconnected height is below 2000mm. I have checked that the cut plain is set below this height & that the drawing is set to medium / fine detail but the lines still do not show. Other walls that continue higher than 2000mm are fine. Any ideas? figure it must be a seeting but not sure which
Detail Component visibility from wall section to detail callout view.
Thu, Oct 8, 2009 at 3:54:42 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
Wall assembly layers not showing in fine detail - Revit 2015
Wed, Nov 19, 2014 at 12:16:01 PM
Wall tag that includes detail reference
Fri, Jul 17, 2015 at 12:50:19 PM
wall tags in detail callout
Tue, Aug 1, 2006 at 9:42:22 PM
Page generation time: 0.6863
