Forums >> Revit Building >> Technical Support >> My walls do not appear in an underlay on my roof plan.
Mon, Jul 17, 2006 at 9:10:13 AM | My walls do not appear in an underlay on my roof plan.
malfonsi
4.5 Stars: 2 Votes
I am trying to show the Upper Level walls in my roof plan as an underlay. It does not show any interior walls and most of the exterior walls. It will show the plumbing fixtures (I turned them off in this view) the base cabinets, stairs, etc. When I use the Main Level as an underlay (for testing) all of the walls show up. Please help me!
Mon, Jul 17, 2006 at 9:56:32 AM | RE: My walls do not appear in an underlay on my roof plan.
coreed
coreed Avatar
4 Stars: 16 Votes
check out this link, the second one sounds like your problem http://revitbeginners.blogspot.com/2006/07/view-range-visibility-lessons.html HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jul 17, 2006 at 10:13:00 AM | RE: My walls do not appear in an underlay on my roof plan.
malfonsi
4.5 Stars: 2 Votes
Thanks for your help. Funny. thing... I remember meeting you about 4 years ago at a Revit seminar and we were both looking into using Revit or ArchiCAD. I see you went the same route we did except we started up on it a little slower than you did. Very Wise.
Mon, Jul 17, 2006 at 10:28:36 AM | RE: My walls do not appear in an underlay on my roof plan.
coreed
coreed Avatar
4 Stars: 16 Votes
sorry, they didin't listen. we just started too.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, May 28, 2009 at 7:14:04 PM | My walls do not appear in an underlay on my roof plan.
sudanhafif
I am having the same problem. some of My second floor walls are not showing below roof plan. The link posted here is not available anymore. Could somebody help
thanks
sudanhafif
Fri, May 29, 2009 at 7:27:34 AM | My walls do not appear in an underlay on my roof plan.
malfonsi
4.5 Stars: 2 Votes
The link worked for me. The following is what the link goes to...........
While in the second floor plan we underlayed the 1st floor plan but the 1st floor plan walls were not visible while doors, windows, and fixtures were. That's because if the top of the wall below intersects the primary range (bottom clip plane) of the floor plan above, then Revit won't include the walls in the underlay. So we had to raise the bottom clip plane which shouldn't have been below the floor level anyway.
I hope this helps
Walls disappear in roof plan after attaching to roof.
Wed, May 30, 2012 at 11:36:02 PM
RAC2008 - Building footprint on Roof Plan
Wed, Aug 15, 2007 at 11:49:47 AM
Underlay.... problems
Tue, Jul 31, 2007 at 11:36:03 PM
Where is my underlay?
Fri, Mar 20, 2009 at 11:43:15 AM
underlay
Mon, Aug 11, 2008 at 6:18:01 PM
Page generation time: 0.7213
