28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> wall join situation?
See attached file.
After selecting the horizontal wall, it shows the blue dot & veritcle red hashmark, signifying the true end point location of the wall. What allows that true endpoint to separate from the visible endpoint when you're in regular drawing mode.
Also, probably the same answer, but what allows the true endpoint location to become abscurred in regular drawing mode
I am not seeing any file attached to your message.
Not sure what I did anymore. I think I fixed it. Anyway went back into file to resave image as a pdf
and couldn't get the same view. Wall join was fixed. I might have done disallow join or something.
If I run into the same situation I'll resubmit the post.
Wall join options |
Wed, Mar 23, 2011 at 7:46:49 PM
Clean wall join |
Sat, Apr 20, 2013 at 3:30:48 AM
11
90degree wall join |
Sun, Aug 20, 2006 at 9:08:54 PM
WALL JOIN PROBLEM - Ends showing in 3D and Elevation View |
Tue, Jul 22, 2008 at 9:38:24 AM
Walls won"t stop |
Fri, May 3, 2019 at 1:04:25 PM
