Forums >> Revit Building >> Technical Support >> shortcut keys
Fri, Jul 14, 2006 at 10:31:34 PM | shortcut keys
ICON
5 Stars: 3 Votes
Where do you go to create your own shortcut keys. Eight years of keyboard shortcuts is hard to give up. Thank in Advance Randy
Sat, Jul 15, 2006 at 12:42:14 AM | RE: shortcut keys
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
"CPuhrogram FilesAutodesk Revit Building 9ProgramKeyboardShortcuts.txt" I think using the keyboard for one thing and the mouse for another works better and faster. That why God gave us two hands
Sat, Jul 15, 2006 at 7:00:39 AM | RE: shortcut keys
ICON
5 Stars: 3 Votes
Thanks, Do I just edit that document by typing my letter choice between the quotation marks or do I need to go somewhere else? I placed PL between the quotation marks and saved the changes. Tried plotting a view using my new PL shortcut but it didn't take.
Sat, Jul 15, 2006 at 8:30:56 AM | RE: shortcut keys
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
Yes, this is the only place to change your shortcuts. When your shortcut doesn't work you have to copy/paste your hole command ex. "U" menu:"Edit-Undo" and paste it on the top part of your file between "File Menu' and 'Preferred order section'
Sat, Jul 15, 2006 at 8:58:08 AM | RE: shortcut keys
ICON
5 Stars: 3 Votes
Still not getting it. I've attached the shorcut file to show what I've pasted to the proper area. Tried to add PL for shortcut to plotting I really want to get this up and running so if you have any more thoughts I'd appreciate it. Thanks Post edited on 2006-07-15 08:59:10
Sat, Jul 15, 2006 at 9:09:40 AM | RE: shortcut keys
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
I just tried this same shortcut on mine "PL" menu:"File-Print" and it worked fine. Check if PL is assigned to another command. Are you pressing the space bar after you press PL? Sometimes you have to press the spacebar and sometimes you don't. You'll learn why when you start using the shortcuts
Sat, Jul 15, 2006 at 11:10:40 AM | RE: shortcut keys
ICON
5 Stars: 3 Votes
Doesn't seem to be applied to another command. All I get is a tone, sounds like an error tone, after I type the "L". Doesn't give me a chance to hit the space bar. I'll play around with it some more. Post edited on 2006-07-15 11:11:19
Sat, Jul 15, 2006 at 11:29:43 AM | RE: shortcut keys
ICON
5 Stars: 3 Votes
I was going to use "U" for a shortcut for "undue". copied it into the upper area. I typed "U" for undue and the information line referenced a different command: menu- settings- project units. I looked on the list of hot keys and it showed the shortcut key for menu- settings- project units is supposed be "UN". Does this make any sense to you.
Mon, Jul 17, 2006 at 2:12:19 AM | RE: shortcut keys
nixn
On the topic of shortcut keys, don't forget about the Revit shortcut highway app you can download in the resources section: http://www.revitcity.com/resources.php
SHORTCUT KEYS
Mon, Jul 30, 2007 at 11:01:01 PM
Use REVIT Shortcut Commands
Wed, Mar 31, 2021 at 7:59:28 AM
using contol or option keys when setting hot keys?
Tue, May 19, 2009 at 11:30:39 PM
Is there a way to pan with arrow keys
Tue, Apr 16, 2013 at 5:56:39 PM
Another Way to Shortcut
Wed, Sep 10, 2008 at 10:44:57 AM
Page generation time: 2.7596
