Forums >> Revit Building >> Technical Support >> symbolic lines
Tue, Oct 28, 2003 at 4:58:21 PM | symbolic lines
SteveB
3.5 Stars: 5 Votes
Is there a way to change the lineweight of a symbolic line? I can only get them to plot at the thinnest possible lineweight. Also the lineweights of various lines in components, such as the electrical fixtures like duplex outlets, switches etc. These are families where the lines are created as symbolic lines. Thanks.
Fri, Oct 31, 2003 at 12:52:55 PM | RE: symbolic lines
Priority
Visibility sets the display for each view by filtering out a particular class of items added to the model. These classes are group into categories and subcategories which have similar function and use in the project. The category is the division in this class and the subcategory is the property of a family that defines its display. By creating a subcategory, and modifying line weight, line color, and line pattern, a user can control how elements in the project are viewed. When creating families always create a subcategory by picking "object styles" located in you settings menu, you can control your visibility a lot better. Example: Category=casework Subcategory= base cabinet Example: Category=electrical fixture Subcategory=junction box In your project you are now able to control the line weight of any piece of casework that has the object style of base cabinet in the project.
Fri, Oct 31, 2003 at 1:05:15 PM | RE: symbolic lines
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
This is very good advice. The usability and efficiency of revit is only as good as the families you use. I think it is extremely important that families are created correctly to provide the greatest degree of manipulation -hj-
Sat, Nov 1, 2003 at 8:35:39 AM | RE: symbolic lines
SteveB
3.5 Stars: 5 Votes
What about the display characteristics of things that are already created. Example in question is the display of an electrical duplex outlet created by Revit: Outlet-Duplex:Single which prints and displays at linewt 1. I'd like to change that: if you open the family separately and clik on a line, the "element properties" window shows the subcategory but not the category. Where is the "category" selection? Best- Steve
Mon, Nov 3, 2003 at 8:40:40 AM | RE: symbolic lines
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
the "category" is most likely "electrical fixtures" go to settings/object styles...modify the lineweight for "electrical fixtures" -hj-
Hiroshi Jacobs
Thu, Jul 13, 2006 at 8:15:41 PM | RE: symbolic lines
tomdbiggs
This is something that I've been wondering about for some time. I finally figured it out, and no you can't just change electrical fixtures linetype under object styles to make the switch symbols and other electrical symbols heavier. In fact, the correct answer to this question is that you have to click the tab "annotation objects". Then scroll down to "generic annotations" and change the lineweight to something heavier. I changed it to 5 and it looks good. For less confusion, let's only post tried and tested how-to instructions to help each other in a more direct way.
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:42 AM
Symbolic Lines Variation in Family
Thu, Feb 15, 2007 at 1:33:21 PM
Symbolic Lines in Profiles.
Fri, Nov 1, 2013 at 4:47:54 PM
Page generation time: 0.7075
