Forums >> Revit Building >> Technical Support >> wrapping of wall inserts
Fri, Jul 14, 2006 at 9:40:12 AM | wrapping of wall inserts
NiDo
we have some problems with the connection of window and wall can you help us to change the wrapping like in the picture of the attachment
Fri, Jul 14, 2006 at 5:13:18 PM | RE: wrapping of wall inserts
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
as mentioned in your other post, wrapping is one of the weak spots of revit. If you require this much control either create the wrapped segments as separate walls or include them in your window family (better option) HTH.
WALL WRAPPING AT INSERTS PROBLEM
Thu, Jan 29, 2015 at 6:56:17 AM
wall wrapping problems
Wed, Mar 4, 2015 at 9:59:02 AM
wall layers not wrapping at curtain wall inserts!
Fri, Mar 4, 2016 at 10:27:08 PM
wall wrapping at curtain wall "inserts"
Tue, May 20, 2008 at 6:29:51 AM
wall layer not wrapping for door family with jambs
Tue, Sep 1, 2015 at 10:34:33 AM
Page generation time: 2.6007
