Forums >> Revit Building >> Technical Support >> plaster on column? "really in trouble"..
Fri, Jul 14, 2006 at 2:06:17 AM | plaster on column? "really in trouble"..
mmetin
mmetin Avatar
what is the way to create column with plaster?.......actually "why columns have no layers? After all, they are made from several materials, starting with concrete, plaster, paint, maybe some other covering option etc."
Fri, Jul 14, 2006 at 2:17:43 AM | RE: plaster on column? "really in trouble"..
gregmeurer
4.5 Stars: 9 Votes
When you create the family for the column, Make sure that you have selected a material for each part of the family. If you are using a column that you have got from somewhere else, just do the same thing by editing the family after you load it into the project. Remember the name the materials for the column so that you can find them once you load them back into the project!! Hope this helps
Fri, Jul 14, 2006 at 8:35:09 AM | RE: plaster on column? "really in trouble"..
Steve_Stafford
5 Stars: 2 Votes
There are two kinds of columns, structural and architectural. Structural columns do not interact with walls. It is assumed that you build walls up to and stop when they reach a column. Architectural columns will join walls that it comes into contact. This means if your wall has a plaster finish the column will acquire one as well. Try it, take a wall and via Modelling menu > Column, place one and move it so it touches or overlaps your wall. Take a look at the column using Thin Lines or change the scale of the view so you can see the linework more clearly. Oh, if these columns are free standing you can paint a finish on the surface of the columns or add a skin to the column family so it can have a material assigned. HTH Post edited on 2006-07-14 08:36:24
Fri, Jul 14, 2006 at 5:19:19 PM | RE: plaster on column? "really in trouble"..
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Following on from Steve's post, there is also an option to disable this.
Sat, Jul 15, 2006 at 1:28:32 AM | RE: plaster on column? "really in trouble"..
mmetin
mmetin Avatar
thanks for help...can we say same thing about beams?.
Tue, Dec 18, 2007 at 9:07:39 AM | plaster on column? "really in trouble"..
sachid
applying plaster to colum is not a big problem only thing is that in colum family add a layer of plaster and lock it with core columand lock it top and base with ref planes in family i t will work
model: column-"properties" dims not scaling to whats shown on drawing
Fri, Dec 12, 2008 at 3:10:11 PM
Specification column "Elevation at Bottom"
Wed, Jan 28, 2009 at 7:43:12 AM
14
Column needs wrapping of wall
Sun, Jan 21, 2018 at 6:01:22 PM
Trouble printing to Oce 30"x42"
Thu, Sep 11, 2008 at 3:51:19 PM
(again, sorry) columns with plaster?
Sat, Dec 9, 2006 at 4:52:30 PM
Page generation time: 3.2982
