Forums >> Revit Building >> Technical Support >> Sloped Surface
Thu, Jul 13, 2006 at 3:02:28 PM | Sloped Surface
arkitektmsh
3 Stars: 1 Votes
what is the best way to create a sloped surface to serve as a driveway? The drive is somewhat u-shaped and the high point is at the bottom of the U. Post edited on 2006-07-26 15:33:12
Fri, Jul 21, 2006 at 2:02:37 PM | RE: Sloped Surface
broncos4life
3.5 Stars: 11 Votes
I would either make a floor and put the slope in on there when you make it, or you can put in slope arrows. I always just make floors and call them out as a driveway. You could also go into the structural tab and make a slab and do the same thing.
Sloped Ceiling Surface Pattern Not Visibile
Sun, Jun 26, 2016 at 7:21:36 PM
Curtain wall on sloped surface
Wed, Jan 7, 2009 at 10:51:56 AM
Applying a timber surface to a sloped steel roof?
Thu, Aug 14, 2008 at 11:22:43 AM
How to edit a curtain wall grid in a curved and sloped surface
Wed, Dec 18, 2013 at 3:40:40 PM
Sloped roof surface pattern grayed.....Revit 2015
Thu, Jan 15, 2015 at 1:48:15 PM
Page generation time: 1.6687
