Forums >> Revit Building >> Technical Support >> Can't Join Floor to Wall
Wed, Jul 12, 2006 at 11:09:31 PM | Can't Join Floor to Wall
cipyboy
hi newbie here, i am trying to make a whole cement plastered wall on the ground and second floors,whenever i place the floor,the walls divide to two. id like my floor to be unified to the walls so the walls wont divide in half... need help thanks cipy
Thu, Jul 13, 2006 at 9:22:28 AM | RE: Can't Join Floor to Wall
SteveB
3.5 Stars: 5 Votes
you are drawing a 2 story high wall? And the floor takes precendence? You could try the "join geometry" icon next to the "offset" tool. You may just have to draw 2 separate floor polygons that butt up to the wall.
Section of wall in length axis: join function doesn't work
Mon, Nov 14, 2011 at 1:31:41 AM
Join wall/floor
Thu, Jul 2, 2009 at 7:07:41 AM
join between wall and floor issue
Thu, Apr 24, 2014 at 10:16:29 AM
JOIN FLOOR AND WALL
Tue, Feb 2, 2016 at 4:58:26 AM
floor to wall joins
Thu, Dec 29, 2005 at 2:45:05 PM
Page generation time: 0.8352
