23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Moving locked walls?
I am trying to move a particular wall to a new position, but an opposite and parallel wall also moves with it.
Is it because it is locked to it, and how do I move my wall independantly of other walls.
I have attached a dwf file showing the situation.
Can anyone help with this?
----------------------------------- VND |
33 Posts No Rating |
Pick the wall you want to move. Choose "Activate Dimensions" and you should she some temporary dimensions with locks on them. Unlock and move.
You may have to manually put a dimension from wall to wall to see the lock. And you may have to try locating the witness lines differently.
Are you the only one working on this project? Can you just ask others on the project what dimension they locked?
Something I should know by now... hmmm... thanks for that I'll give it a try and see if that's been the problem.
moving walls |
Tue, Aug 6, 2013 at 8:54:03 PM
two walls heights locked, I want to unlock |
Mon, Sep 1, 2014 at 2:52:35 PM
Parallel walls locked in relation to one another? |
Thu, Apr 27, 2006 at 10:53:42 PM
walls moving together |
Fri, Mar 23, 2012 at 3:36:35 PM
MOVING AND ALIGNING WALLS |
Sat, Mar 10, 2012 at 5:57:39 AM
