12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> demolition graphics
Is it possible to change the way demo objects (when shaded w/edges) show up as red?
In the Phases window, you can set the graphic overrides for any object which is being demo'ed. In a shaded view it is done with the material selected. Typically the graphic override is setup to go to the "Phase-Demo" material which is transparent red. You can go into the material editor and modify/duplicate this material, and then reassign it on the Graphic Override Tab of the Phases window(Settings > Phases).
Of course, if you don't want the demo'ed object to show at all you should chagne the phase filter for the view.
Hope that helps.
Calculate Demolition |
Fri, May 8, 2015 at 3:56:11 PM
Modelling a demolition project in Revit |
Thu, Feb 11, 2016 at 10:08:26 AM
Demolition Lines Scale wrong / not showing with components. |
Mon, Oct 22, 2007 at 9:55:09 AM
Setting wall to demolition, infills - how to stop? |
Fri, Aug 5, 2016 at 11:24:18 AM
Edit Demolition Profile Tool |
Wed, Mar 1, 2006 at 4:43:33 PM
