Forums >> Revit Building >> Technical Support >> Importing DWG or DXF file objects
Wed, Jul 12, 2006 at 8:27:57 AM | Importing DWG or DXF file objects
eemix
eemix Avatar
3 Stars: 2 Votes
Hello to all users In my projects i use to import furnitures (sofas,chairs,tables etc) from dwg files But i have now a problem. Anything i import, in rendering it appears grey, even i change the materials of it, through Settings-Object Styles-Imported objects where i give to the imported object a material to each layer. I had the the same problem 5 months ago (i stopped using revit during these months), and somehow i found a solution. But it was (as it seems) by luck and not by knowledge. Did someone of you, have the same problem and what should i do? Please any help would be very but very welcome...
Wed, Jul 12, 2006 at 9:46:55 AM | RE: Importing DWG or DXF file objects
Elmo
3.5 Stars: 4 Votes
You need to edit the autocad file and assign the different components seperate layers. Then you can change the materials in Revit. I would rather try to model it in revit and assign my materials there.
Wed, Jul 12, 2006 at 10:45:32 AM | RE: Importing DWG or DXF file objects
eemix
eemix Avatar
3 Stars: 2 Votes
Editing items in revit is not that simple and the results aren't such real, as from autocad or viz Thanks for answering
Importing .3ds objects into revit OR a WORKAROUND??
Fri, Aug 7, 2009 at 10:23:19 AM
Problems importing .dwg or .dxf.................................
Mon, Feb 25, 2008 at 11:12:13 AM
DWG/DXF layers.
Wed, May 31, 2017 at 7:05:57 AM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
rendering imported dxf objects?
Thu, Aug 17, 2006 at 10:32:49 PM
Page generation time: 0.5637
