Forums >> Revit Building >> Technical Support >> Printing issue
Tue, Jul 11, 2006 at 8:46:54 PM | Printing issue
geoffy
Some of my students are having problems printing their project sheets- The correct views appear in print preview as you would expect but when printed not all views show (these are predominantly model elevation views) rendered views & JPEG images appear on the printed sheets though. Is this a printer memory issue? Your help/advice appreciated.
AutoCAD & Revit TAFE teacher from regional Australia
Wed, Jul 12, 2006 at 1:12:21 AM | RE: Printing issue
Ultramarine
I had the same problem using Revit 8.1 if I had both elevation and rendered images on the same sheet. It seems the problem has been fixed in Revit 9, as I haven't had any problems since upgrading.
Printing changes annotations on sheets
Thu, Sep 15, 2016 at 6:55:41 AM
Scope boxes printing, set not to print.
Tue, Feb 15, 2011 at 6:39:49 PM
Revit printing issue
Wed, Nov 23, 2011 at 10:36:07 AM
double printing Revit 2018
Mon, Jul 9, 2018 at 3:35:04 PM
printing in revit
Thu, Oct 22, 2009 at 10:26:33 AM
Page generation time: 0.5391
