Forums >> Revit Building >> Technical Support >> Poche Walls
Wed, Sep 22, 2004 at 1:22:33 PM | Poche Walls
Osir
Does anyone know of a way to have all walls poched (or visually filled in) in plan?
Wed, Sep 22, 2004 at 6:39:29 PM | RE: Poche Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Do you mean adding a cut fill pattern? There are two settings for cut fill, that is by material and at coarse scale setting you have a separate coarse scale cut pattern for each wall type in its properties. Just edit the appropriate material that makes up your wall in the settings drop down menu and add a cut pattern to the material... I apologise if i've misunderstood your query... Post edited on 2004-09-22 18:39:54
Wed, Sep 22, 2004 at 7:14:05 PM | RE: Poche Walls
Osir
Thanks, that does it! Its a little buried, but now that you've pointed it out, it will be handy. Here's the route: Select Wall-->Properties Icon-->Edit/New-->Course Scale Fill Pattern-->CryingDesired fill pattern... I used 'Solid Fill'Winking However... it seems that In-Place Wall families are not as easy to fill. Any idea how to do this? Again, thanks for the pointer.
Wed, Sep 22, 2004 at 8:50:39 PM | RE: Poche Walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just find the material you've set for the in-place wall family. Go to Settings - > Materials --> Find the material in the left list and select it --> Where it says cut pattern, select the arrow at the far right and select an appropriate pattern, in your case solid fill. Then select a colour for the fill. There you go.
Mon, Jun 23, 2008 at 11:50:28 AM | Poche Walls
notagain
notagain Avatar
4 Stars: 1 Votes
It took me a little bit to figure this one out.  But what exactly is the Coarse Scale Fill Pattern used for? Maybe I am not that far along..but so far I don't see anything from it.
I really want this to work...some good things some bad
Mon, Jun 23, 2008 at 2:11:53 PM | Poche Walls
I sometimes use this feature to check my wall type locations.  By giving each interior wall type a different coarse color, I can quickly verify that I have the correct wall in the correct place.  Easy to change out when I am ready to final plot.
Wall Poche and Phasing....
Wed, May 31, 2017 at 8:40:33 AM
poche walls
Wed, Jul 25, 2007 at 1:26:04 PM
Walls, Floors and Roofs to show hatch pattern AND color poche?
Sun, Apr 29, 2012 at 12:24:19 PM
Underlayer Leaves Ghosting in Poche
Fri, Mar 13, 2015 at 7:49:29 PM
revit 2016 poche
Wed, Sep 23, 2015 at 2:50:33 PM
Page generation time: 2.1467
