Forums >> Revit Building >> Technical Support >> wall Joins
Mon, Jul 10, 2006 at 11:53:38 PM | wall Joins
A5Len
Is there a specific logic that revit follows to generate wall joins ie corners in plan? Often i have a situation where revit creates a join that is not the most logical way and definately not the way it would be built. Just wondering what criteria revit uses when creating a join.
Tue, Jul 11, 2006 at 6:37:01 PM | RE: wall Joins
MarieCz
Umm well i dont know about criteria, but u can edit ur wall joins. Tools > Edit Wall Joins. and place ur mouse over the join and it will give u choices like mitre, butt, square off etc. in your Options bar. So you can change how it joins if you like. Thats about it. Although it doesnt like to work very well if your joining walls from different heights or different levels, its a bit odd but generally works. Hope that helps :D
Thu, Jul 13, 2006 at 1:23:01 AM | RE: wall Joins
A5Len
Thanks, did some searching the net and discovered that by right clicking on the blue dot at the end of a wall you can "disallow join", then drag walls to positions and then join them with the join geometry tool in the order of preference you require
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
I hate the Revit Automatic Wall joins
Thu, Oct 25, 2007 at 9:59:44 AM
wall joins
Thu, Oct 20, 2011 at 4:37:14 PM
Page generation time: 2.9214
