Forums >> Revit Building >> Technical Support >> Importing .dwg details
Mon, Jul 10, 2006 at 4:39:54 PM | Importing .dwg details
ArchWestCY
4.5 Stars: 7 Votes
I have a big project, and need to import many pre-drawn details form AutoCAD. I have imported .dwgs before, and I intend to import these to drafting details for placement on Revit sheets. My question is can Revit recognize an AutoCAD .ctb? How does Revit determin the lineweights of imported .dwgs? <By Category> is what it says in the Visibility/Graphics dialog. What Category, how do I set the category? As always any help is greatly appreciated. Archwestcy
Tue, Jul 11, 2006 at 10:00:13 PM | RE: Importing .dwg details
goum
If you go to File-> Import/Export Setings->IMport Line Weights DWG/DXF. You should be able to set line weights in the Revit file corresponding to the .DWG colours.
GN Brisbane, Q Australia
Wed, Jul 12, 2006 at 12:23:47 PM | RE: Importing .dwg details
ArchWestCY
4.5 Stars: 7 Votes
Thanks. I found what you were talking about (Import/Export Settings => Import Lineweights DWG/DXF). I found that you can create several "importlineweights" files for all of the differant .ctb styles that you may run into. Then, when importing a .dwg you can chose which one to use. This is going to help out a lot. Thanks ArchWestCY
not to see imported dwg on every level (after importing dwg)
Sun, Nov 26, 2006 at 11:13:58 PM
Is anyone successfully importing dwg's without problems?????????????????????????
Wed, Jun 3, 2009 at 12:39:13 PM
Problems importing .dwg or .dxf.................................
Mon, Feb 25, 2008 at 11:12:13 AM
Importing .dwg Details - Model Space vs. Paper Space
Wed, Aug 9, 2006 at 5:37:45 PM
Importing dwg as underlay
Sun, May 24, 2020 at 10:56:19 PM
Page generation time: 3.5952
