22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Offset lines from extrusions?
9 Posts No Rating |
Beginner here. I just went through the first part of Daniel John Stine's new _Residential Architecture Using Autodesk Revit Building 9_, and learned the technique of easily drawing complex-yet-repetitive shapes (like furniture) by picking existing lines and using the offset tool to copy and modify them. He gives all his examples in drafting views, however, and I want to create true 3D families.
So I went through the rolltop desk tutorial, and now I can create 3D extruded families. It seems that there are two basic ways to create a solid extrusion: draw it in symbolic lines and then pick them from the extrusion sketch, or draw them with line-lines in the extrusion sketch itself. Method #1 lets me use offset on the symbolic lines, but then it leaves symbolic lines all over the place after the extrusion's created. Method #2 keeps the drawing clean, but I can't seem to offset new lines off an extrusion.
Is there a method #3, or a way around this? Do most people just use symbolic lines, and then clean them up with a filter at the end?
Void extrusions |
Wed, Apr 8, 2009 at 5:23:38 AM
Joining extrusions |
Tue, Jul 26, 2022 at 3:58:08 PM
Possible to specify the starting offset object? |
Thu, Aug 29, 2013 at 1:47:59 PM
Gaps in lines closing up automatically |
Sun, May 23, 2010 at 1:38:48 PM
naming extrusions |
Thu, Oct 10, 2013 at 10:00:24 AM
