Forums >> Revit Building >> Technical Support >> (again, sorry) columns with plaster?
Mon, Jul 10, 2006 at 12:37:25 AM | (again, sorry) columns with plaster?
mmetin
mmetin Avatar
what should i do to create plaster around a column?
Thu, Dec 7, 2006 at 8:15:53 PM | (again, sorry) columns with plaster?
thnieves
Hi,
 I'm having the same problem here. I want to use concrete structural columns and beams inside the walls CryingI put them there but they wont show up) and I also want to have columns with plaster finish.
Fri, Dec 8, 2006 at 5:43:28 PM | (again, sorry) columns with plaster?
normanoid
First, to make a column visible that is hidden within a wall, use the "Unjoin Geometry" tool on the column to seperate it from the wall.
Second, to put plaster on a column, you may use one (or more) of the following options:
  1. Edit/duplicate the existing family and add the "plaster" layer to the model. (family modeling techniques required which I will not explain. There are pleanty of tutorials available)
  2. Create a new wall type consisting of "plaster" only and surround the column with it. (This will require seperating the column from the wall as mensioned above.)
  3. Just add detail lines around the column to represent a layer of plaster.
Edited on: Fri, Dec 8, 2006 at 5:43:58 PM
Edited on: Fri, Dec 8, 2006 at 5:46:08 PM
Sat, Dec 9, 2006 at 4:52:30 PM | (again, sorry) columns with plaster?
thnieves
Thanks Normanoid! Nice help.
Tue, Jul 4, 2006 at 6:29:22 AM
plaster on column? "really in trouble"..
Tue, Dec 18, 2007 at 9:07:39 AM
How do I apply plaster to structural Concrete Columns
Tue, Mar 4, 2014 at 1:09:38 PM
PLASTER WALLBOARD FAMILY
Fri, Mar 24, 2017 at 10:10:46 AM
Single Timber stud to double stud wall doesnt wrap the plaster at the end.
Wed, Aug 8, 2012 at 5:18:19 PM
Page generation time: 0.3702
