13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> sections and level lines
when I create a sections, not all of the level lines show up. In this case the main floor level line was missing.
Can anybody enlighten me.
Thanks,
Randy
When you say your main floor level line is missing, what is this level called specifically? I know that if you make a copy of any level in the project browser box and then rename it... It won't show up in the section. I'm not sure if this is the case with yours. Does that help?
Thanks for the info. I wasn't aware of that.
In this case it turns out that I needed to adjust the cropping window so that it intersected the level line.
Levels in Sections |
Fri, Jun 1, 2007 at 4:05:29 PM
2014 Level Head Adjustment in Sections/Elevations/Etc. |
Thu, Mar 13, 2014 at 1:08:44 PM
I have new elevation views in a second building but want the level lines to show |
Wed, Jul 25, 2012 at 7:22:45 AM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain |
Sun, Dec 2, 2012 at 7:34:52 PM
Sections, different level/views |
Sat, Aug 5, 2017 at 7:34:44 AM
