Forums >> Revit Building >> Technical Support >> Beam questions
Wed, Sep 22, 2004 at 1:00:42 AM | Beam questions
CG
Hi guys I'm new here but i find this forum to be so interesting that's why y signed up. I hope I can be helpful some time too! OK. here is my issue. I need to know if there is any way I can change the shape of a beam end. I need to use a profile with angles and arcs. On the other hand I need a clean intersection of two beams with oposite slopes. How do I do that? Thank you very much.
Fri, Sep 24, 2004 at 9:08:35 PM | RE: Beam questions
ajmcneill
CG, i'm pretty new to Revit myself but from what i understand so far, to answer your 2nd question, if you're using structural beams then there is no "real" way to clean-up the intersection. You can use "linework" and together with the "invisible" line tool (& the others) you can clean it up that way. Someone with more experience may be able to confirm (or trash) my answer here.
Tue, Sep 28, 2004 at 12:54:51 AM | RE: Beam questions
papurajx
Open the 'Beam' family in the family editor and add 'Void/solid' to change the shape of the beam ends.
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
beam - how to show overhead? single line
Wed, Jun 10, 2015 at 9:52:25 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Beam & Beam systems
Tue, Oct 21, 2008 at 4:36:54 PM
Page generation time: 0.7338
