Forums >> Revit Building >> Technical Support >> Dumb beginner problem loading wall sweep profile
Sat, Jul 8, 2006 at 9:42:00 PM | Dumb beginner problem loading wall sweep profile
JayLevitt
Working in Revit 8, I created a very simple hosted wall sweep for a window sill, and used it successfully in a project. I'm now on Revit 9. I loaded and re-saved the profile so it would be a Revit 9 family, and then I selected File > Load from Library > Load Family... and loaded the sweep. It shows up under "Profiles". However, when I select Host sweep >> Wall Sweep, it doesn't appear! "Load..." is greyed out there. I'm sure I'm doing something fundamentally wrong, but I can't figure out what... help?
Sun, Jul 9, 2006 at 6:42:08 AM | RE: Dumb beginner problem loading wall sweep profile
Dgodfrey
4 Stars: 4 Votes
Your profile is fine, but you will need to load it into your "type selector" pull down by selecting any of the available wall sweeps in the pull down as if you were going to insert them into the drawing. Select, "Edit/New" | "Duplicate"| , name your New Sweep, and then under the "Construction" Parameter, select profile down arrow and your project profiles will now be accessable to your Wall Sweeps.
Sun, Jul 9, 2006 at 7:05:12 AM | RE: Dumb beginner problem loading wall sweep profile
JayLevitt
Ohhhhhh! Thanks, that works perfectly.
Revit 2012 having trouble loading profile family for wall sweep
Sat, Jun 11, 2011 at 3:20:42 PM
11
Problem loading profile for slab edge sweep.
Mon, Oct 22, 2007 at 8:04:06 AM
Wall Sweep profile family problem
Tue, Oct 2, 2012 at 6:41:22 PM
wall sweep on a wall with a custom profile
Wed, Dec 2, 2009 at 5:48:07 PM
Custom profile for wall sweep
Mon, Jul 1, 2013 at 2:06:01 PM
11
Page generation time: 3.1737
