Forums >> Revit Building >> Technical Support >> hiding some walls of the same type
Fri, Jul 7, 2006 at 7:13:58 PM | hiding some walls of the same type
zubbo
can somebody help please, i have a particular wall type in my project and i want to hide only some of the walls so they don't show when i print i have selected the walls i don't want to see and hidden them in the sheet view but they still print. also whats the best way to set up a project so you can isolate wall types to turn off. p.s. thanks for any reply.
Sat, Jul 8, 2006 at 12:34:16 PM | RE: hiding some walls of the same type
dduarte
dduarte Avatar
3 Stars: 2 Votes
Put the walls you want to turn off in their own workset. Turn off the workset in VG. You could also try Design Options but I haven't tested it yet myself. Post edited on 2006-07-08 12:35:33
Sat, Jul 8, 2006 at 6:14:00 PM | RE: hiding some walls of the same type
zubbo
thank you for your time dduarte.
Sun, Jul 9, 2006 at 3:40:36 AM | RE: hiding some walls of the same type
puzzle
4 Stars: 10 Votes
If you are using Revit 9 you can use filters.
Macca
Sunshine Coast
QLD Australia
Hiding linked Walls by Wall Type???
Wed, Oct 12, 2011 at 2:48:13 PM
Hiding walls
Sun, Apr 17, 2005 at 3:55:24 AM
Demolished walls hiding proposed stuff
Tue, Sep 20, 2016 at 5:54:34 PM
HIDING FLOOR EDGES ON WALLS
Fri, May 24, 2019 at 4:00:10 AM
Filled Region <invisible lines> overlapping and hiding surrounding lines
Mon, Feb 4, 2008 at 10:41:34 AM
Page generation time: 1.3553
