Forums >> Revit Structure >> Technical Support >> Views: Structural Plans vs Floor Plans
Fri, Jul 7, 2006 at 4:59:18 PM | Views: Structural Plans vs Floor Plans
k1PE
ref software: Revit Structure 3 i am trying to learn about views family when i start with structural temp i get 2 levels and 2 level - analysis under structural plans and a building elevation whereas in Revit Building Temp i get 2 - levels, site, Cieling, and 4 elevation under Floor and Elevation Plans. how can i modify structural temp so i can get Floor Plans. when i try to draw architecture element in structural plan doesnt let me. also as a structural engineer when i start a project, under tuterial is just showing me how to start by importing AutoCAD, Revit, or ADT it doesnt tell me how i can start when i have a set of hard architectural drawings. do i need to draw architectural elements wall, door, openning, ... Most Project i Work on are custom residential houses (wood Structures) so its bearing wall sustem dont use any columns in most cases maybe under main mambers and headers. so my main question is whats the best way for me to start working on a project, also some help with view families, also dont refer me to AUG i am already member not getting anything from the tuterials and Forums for Revit Structure
Floor plans to Structural plans
Fri, May 4, 2012 at 11:13:28 PM
Structural Plans vs Floor plans
Mon, Jan 30, 2017 at 11:49:20 PM
Enlarge Floor Plans
Thu, Feb 12, 2009 at 4:12:21 PM
12
VERY INTERESTING QUESTION
Thu, Sep 11, 2014 at 7:11:22 PM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
Page generation time: 0.5090
