Forums >> Revit Building >> Technical Support >> importing profiles to template file
Fri, Jul 7, 2006 at 4:09:15 PM | importing profiles to template file
ICON
5 Stars: 3 Votes
I've run across a profile in a Revit drawing file that I'd like to import into my template file. I've played around, but haven't figured out how to do that. Any suggestions? Thank you in advance. Randy Post edited on 2006-07-07 19:45:47
Fri, Jul 7, 2006 at 10:47:09 PM | RE: importing profiles to template file
ICON
5 Stars: 3 Votes
never mind, just copied to the clip board and pasted. I just have to figure out how to edit the profile, when I do a host sweep the profile comes in ok but it unsatisfactorily overlaps other objects by a couple of inches. should be able to edit that somewhere.
Fri, Jul 7, 2006 at 11:40:23 PM | RE: importing profiles to template file
ICON
5 Stars: 3 Votes
TEXT TAKEN FROM HELP MENU: "Editing the Sweep You can quickly edit either the path or the profile of the sweep from the Options Bar. Click Modify, select the sweep geometry, and then click either of the following: Edit Path to edit the path sketch. Edit Profile to edit the profile sketch." Think I'm just tired, I'm just not seeing the modify option in the "options bar" I'm taking the options bar to be the bar with the filter icon in it. Any thoughts, Randy
Save an existing project file as a template file
Mon, Oct 26, 2009 at 1:11:47 PM
Importing CAD Line Styles - Auto Convert?
Thu, Jun 14, 2012 at 4:04:27 PM
Inserting stringer profiles
Wed, Mar 5, 2014 at 7:23:53 AM
Base Project template
Wed, Mar 22, 2006 at 10:09:57 PM
how to convert a template to project file in 2012
Fri, Aug 2, 2013 at 2:58:22 AM
Page generation time: 0.4812
