20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> STAIRS
CAN ANYONE TELL ME HOW TO CREATE STAIRS LIKE THE ONES SHOWN ON THE LEFT IN THE ATTACHED FILE? I WILL WANT THEM TO BE WOOD FRAMED.
HERE IS THE FILE
39 Posts No Rating |
I tried to download your file - i did but then it wouldnt open, it said it had too many bytes....?!
Try again with a smaller file or explain it :D
You'll need to create it as 3 separate pieces in order to make it show as timber framed.
The 2 risers and the u-shaped section will be one,
The square landing will be a floor
and the riser at the door way will need to be another stair.
HTH.
Either that or just model it in place. Its only small and you'll probably achieve what you want quicker modelling in place.
This stair is constructed of only one stair object. If you like the result, then download the corresponding Revit file with the following link and take a closer look at it, everything is in there for real (2.424mb);
http://rapidshare.de/files/25413125/Project267_U-Stairs.rar.html
Post edited on 2006-07-09 20:30:56
Wrapping stairs |
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs |
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above |
Fri, Feb 17, 2012 at 1:44:46 PM
Spiral Stairs around a Central Post |
Sat, Apr 16, 2011 at 9:27:29 AM
Help with stairs |
Fri, May 4, 2018 at 7:32:59 AM
