23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Column Visibility in Callout Detail
2 Posts No Rating |
I am unable to determine why my structural columns appear in one detail callout view but do not appear in another detail callout view. When I copy and paste the same view with desired and correct strcutrual column visiblity into the same 'parent' plan it works, but if I cut and paste into another level it does not work.
1. I have made sure that the columns are in the correct workset and workset is visible.
2. The columns are 'structural' columns and VG is correct.
3. Unfortunately, I am unable to post the project for troubleshooting.
Thank you for the help. Any advice is appreciated.
11 Posts No Rating |
Without seeing what you have, you may want to just look at the View Properties for both levels.
2 Posts No Rating |
I found a work-around (in other online forums) .
For others with the same issue, if you 'join' the column to the structural slab it then appears in the callout detail (that is why it appeared in one of my views). This seems like a Revit bug, but there may be some other revit-logic for structural columns to behave this way.
Thank you bobg for the post.
209 Posts No Rating |
Open family go to settings-family categories and parameters- uncheck the show family precut in plan view. HTH
Hi, this post was in July 2006, more than 2 years...
Detail Component visibility from wall section to detail callout view. |
Thu, Oct 8, 2009 at 3:54:42 PM
Roof Detail Callout Visibility? |
Tue, Aug 8, 2006 at 5:48:07 PM
plan detail callout in section [ 1 2 ] |
Fri, Mar 29, 2013 at 12:48:11 PM
15
Help with visibility of components and detail lines in plan view and callout? |
Tue, Nov 27, 2007 at 1:12:14 PM
Detail callout vs. Floor plan callout |
Mon, Nov 2, 2009 at 11:03:39 AM
