Forums >> Revit Building >> Technical Support >> Create batting lines
Tue, Jul 4, 2006 at 7:04:28 AM | Create batting lines
artchitects
I'm wondering 1. It's about insulation batting lines (the line in the draftingtablet which can go to infinity): can I create a line type of my own, which behaves the same as the insulation batting line? 2. Can I create fill patterns on an easy way (not changing the whole .txt script)?
Tue, Jul 4, 2006 at 9:55:05 AM | RE: Create batting lines
Elmo
3.5 Stars: 4 Votes
1. Have you tried creating a new line style and see if that works? 2. There are number of hatch pattern programmes out there. I would recommend using Hatchkit.
Tue, Jul 4, 2006 at 2:12:19 PM | RE: Create batting lines
artchitects
tx for the reaction... Well I'm actually searching for a zigzag line, which you can use in drafting up your details. The insulation batting line is very handy because you can decide how long the line will be. That is not possible with normal lines (also with the lines I created). Jelle
Insulation Batting lines
Mon, Jul 3, 2006 at 5:32:26 PM
Curved Insulation Batting
Fri, Oct 23, 2015 at 8:59:11 AM
INSULATION
Mon, Dec 11, 2006 at 4:58:56 PM
Lenght Detail Lines
Tue, Feb 10, 2009 at 1:39:04 AM
Ramp Boundary Lines / Run Lines / Landing Lines
Wed, Feb 18, 2009 at 2:29:37 PM
Page generation time: 0.7633
