8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Skillion roof pitched on two sides - gif attached
3 Posts No Rating |
Does anyone know how to create a skillion roof which pitches front to back and side to side? i.e. rolls around an axis from two opposite corners. See gif attached if not clear what I am after.
You already have it made, just go to massing and do a Roof by Face,
Then delete your mass
3 Posts No Rating |
Ehrrr, of course, thanks...
5 Posts No Rating |
Is there some way to do this without modelling a mass? I have the same problem.
Use a slope arrow to define the roof pitch instead of the sketch lines...
Regards,
Chris.
5 Posts No Rating |
Thanks. I had a couple of problems with the "can't create roof footprint" error. But I got it under control.
5 Posts No Rating |
I have another problem. What happens if I want to have a valley running from opposite corners ? Do i have to model it with a mass? How do I do that?
Skillion roof with pitched on two sides |
Mon, Jul 3, 2006 at 6:20:11 PM
Challenging Skillion roof...?! |
Wed, Nov 22, 2006 at 6:15:39 AM
Pitched, angled & tilted roof |
Fri, Sep 26, 2014 at 2:26:26 AM
a pitched hip roof with an arched dormer window and standing metal seam finish |
Wed, Nov 13, 2019 at 5:31:44 AM
demolish part of pitched roof |
Fri, Jan 13, 2006 at 2:28:37 AM
