Forums >> Revit Building >> Technical Support >> Site Materials in 3d views with a complex site
Fri, Jun 30, 2006 at 6:05:05 PM | Site Materials in 3d views with a complex site
JBorst
I have a very large, complex site generated from a survey and I have several different materials mapped to different subregions, and when I look at it in plan or elevation my material colors show up, but when I switch to a 3d view or a section, all the colors go default gray. Strangely, it only affects the site surface, not any of the other modelling. Has anyone else run into this? Look at the picture for more info.
Fri, Jun 30, 2006 at 6:51:51 PM | RE: Site Materials in 3d views with a complex site
coreed
coreed Avatar
4 Stars: 16 Votes
check this question and answer link, it sounds similar to your problem http://autodeskrevitbuilding.blogspot.com/2006/05/visibilityfilters_29.html HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Jun 30, 2006 at 7:03:31 PM | RE: Site Materials in 3d views with a complex site
JBorst
Both my ground plane check boxes were unchecked, I had found the one in sun and shadow settings earlier, but not the environment one, so that's good to know about, but I don't think that it's a ground plane issue. It seems more like revit decided to generalize it to save memory, but I don't know where to go to override that or if that's even the case. It's not doing this on less complex site models, just this one. Any other thoughts?
Fri, Jun 30, 2006 at 8:10:07 PM | RE: Site Materials in 3d views with a complex site
puzzle
4 Stars: 10 Votes
Has everything been phased correctly.
Macca
Sunshine Coast
QLD Australia
Sat, Jul 1, 2006 at 9:59:04 PM | RE: Site Materials in 3d views with a complex site
eldados
eldados Avatar
4.5 Stars: 8 Votes
silly questions but: what is the detail is set to? and have you unloaded the dwg file? have you tried to change the material?
Integrator
KarelCAD
Sun, Jul 2, 2006 at 11:00:02 PM | RE: Site Materials in 3d views with a complex site
goum
I would agree with Macca. It seems to me it may be a phasing problem. Check the phasing under the View Property settings. Usually when a Topo surface is altered or split etc, another surface is created which is assigned the default colour, usually grey. Check to see if you have two topo's, one showing the original material and another with the default. Assign the required phase to each surface and set your VP to show the desired phase.
GN Brisbane, Q Australia
Mon, Jul 3, 2006 at 12:02:51 AM | RE: Site Materials in 3d views with a complex site
hisdirt
5 Stars: 5 Votes
Another silly question... whats the scale set to in that view? The grey you're talking about might be the surface pattern at a really fine level...
Mon, Jul 3, 2006 at 4:32:18 PM | RE: Site Materials in 3d views with a complex site
JBorst
It was a phasing issue. Even if I had it showing previous phase drawings it was gray. I was adjusting the wrong things. Thanks for the help
Problem with site shading with edges
Sun, Mar 8, 2009 at 3:59:32 PM
need materials
Wed, Jan 30, 2013 at 3:31:41 AM
Site Plan
Tue, Jun 30, 2009 at 3:46:47 PM
Site plans and Linking with Master files
Fri, Jul 7, 2006 at 6:55:40 PM
create a new site floor plan
Tue, Jul 14, 2009 at 11:54:24 AM
Page generation time: 0.5640
