Forums >> Revit Building >> Technical Support >> Materials Not rendering
Mon, Sep 20, 2004 at 9:51:55 AM | Materials Not rendering
jdvrana
I have poured conc. walls and added paint as a material on both sides but it still renders gray. I tried placing the finish material outside of the core limits with no different results.
Jeffrey
Mon, Sep 20, 2004 at 5:37:16 PM | RE: Materials Not rendering
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Check the material you painted the wall with in the material settings and see if the accurender material has been defined properly, ie: not a lost link and is the desired result.
Rendering Materials
Wed, Sep 13, 2006 at 1:13:06 PM
Revit materials missing at rendering [ 1 2 ]
Tue, Jun 14, 2011 at 11:24:21 PM
22
Revit Custom Materials Rendering Objects invisble
Mon, Mar 14, 2011 at 10:42:55 AM
13
some materials not rendering in perspectives
Thu, May 23, 2013 at 3:00:34 PM
rendering issue
Mon, May 21, 2007 at 1:39:08 PM
Page generation time: 0.3970
