Forums >> Revit Building >> Technical Support >> Turning floor surfaces off for individual floor elements?
Wed, Jun 28, 2006 at 8:33:54 PM | Turning floor surfaces off for individual floor elements?
vnd
3 Stars: 2 Votes
Is there a way to turn individual floor surfaces off in views. Ie on the floor plan I have internal floor surfaces which i want to show in my view, and then i have external, such as concrete paving surfaces which I don't want to show in my view. How do I turn just these surfaces off?
VND
Wed, Jun 28, 2006 at 9:37:32 PM | RE: Turning floor surfaces off for individual floor elements?
puzzle
4 Stars: 10 Votes
If you are using Revit 9 then filters are the way to go. Tuturiols are very helpful.
Macca
Sunshine Coast
QLD Australia
Wed, Jun 28, 2006 at 10:05:28 PM | RE: Turning floor surfaces off for individual floor elements?
vnd
3 Stars: 2 Votes
How about working with 8.1... not possible?
VND
Wed, Jun 28, 2006 at 11:06:43 PM | RE: Turning floor surfaces off for individual floor elements?
puzzle
4 Stars: 10 Votes
Pretty sure you can't in 8.1. Have heard of people using worksets but I'm not used worksets at all.
Macca
Sunshine Coast
QLD Australia
Wed, Jun 28, 2006 at 11:13:11 PM | RE: Turning floor surfaces off for individual floor elements?
MarieCz
Obviously you can turn all the floor surface patterns on or off in your view properties> floor> surface pattern. If this is what you mean. Or just do a blank Filled Region over the area you dont want to see. :D
Thu, Jun 29, 2006 at 12:41:32 AM | RE: Turning floor surfaces off for individual floor elements?
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
Model the floors that you want to turn off with a generic models I think this is the best way if you don't have filters.
Thu, Jun 29, 2006 at 1:23:41 AM | RE: Turning floor surfaces off for individual floor elements?
vnd
3 Stars: 2 Votes
What do you mean exactly by the generic models?
VND
Thu, Jun 29, 2006 at 1:31:20 AM | RE: Turning floor surfaces off for individual floor elements?
puzzle
4 Stars: 10 Votes
Go to modelling & down the bottom is create. Pick generic model give it a name then use solid extrude to make your floor.
Macca
Sunshine Coast
QLD Australia
Floor drain slopes adding lines to the slope when modifying sub elements
Tue, Oct 16, 2012 at 3:55:57 PM
Turning off 3d door in floor plan
Sat, May 23, 2009 at 3:55:42 PM
Room treatments... as in interior design
Tue, Jul 24, 2007 at 12:19:58 PM
How to take quantities from painted surfaces?
Tue, Oct 10, 2017 at 1:00:43 AM
How can you place a ceiling in a floor if theyre both 3D elements???
Wed, Dec 3, 2014 at 12:26:40 PM
Page generation time: 0.5953
