Forums >> Revit Building >> Technical Support >> missing walls, fixtures in pdf prints
Wed, Jun 28, 2006 at 3:42:18 PM | missing walls, fixtures in pdf prints
shannonfm
I sent my first revit prints to the company that prints our 24X36 dwgs last week. I sent them as PDFs using CutePDF. I noticed in the print preview that random walls (the windows remained) , plumbing fixtures, and even half of a circle were missing. I sent the prints anyway, it had been a long day. Also my existing walls showed up as lines composed of closely spaced dots. Does anybody now how to remedy this problem?
Wed, Jun 28, 2006 at 7:46:42 PM | RE: missing walls, fixtures in pdf prints
eldados
eldados Avatar
4.5 Stars: 8 Votes
never came across this, when you view your PDF is it in 100%?
Integrator
KarelCAD
Mon, Jul 3, 2006 at 3:41:57 PM | RE: missing walls, fixtures in pdf prints
shannonfm
The image on the screen is missing all the items that don't print. The other sheet in the file printed fine w/o any omissions. If I print only the view in question to my laser printer on 81/2x11 it prints fine. It seems to be when I want the entire sheet w/ multiple views that I have a problem.
Wall Solid Fill Cut Pattern Jagged on PDF
Fri, Apr 3, 2015 at 10:36:32 AM
Print to PDF
Fri, Jan 23, 2015 at 6:47:45 AM
Issues while making PDF
Wed, Jan 13, 2016 at 4:31:00 PM
Lighting Fixtures on Walls
Mon, Aug 30, 2010 at 12:39:30 PM
printing PDF files
Sun, Mar 13, 2016 at 12:33:02 PM
Page generation time: 2.3338
