Forums >> Revit Building >> Technical Support >> Saving a family fom project to family editor
Thu, Sep 16, 2004 at 1:43:44 AM | Saving a family fom project to family editor
liam
I am wandering if anyone knows how to save a family that has been created in a project, into a database containing other families that were created in the family editor. any comments on the subject would be greatly appreciated. thanks
Thu, Sep 16, 2004 at 9:32:46 AM | RE: Saving a family fom project to family editor
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I don't think you can do that. I believe the only families you can save out of a project are families that have been loaded in, not those created in.
Hiroshi Jacobs
Thu, Sep 16, 2004 at 5:12:57 PM | RE: Saving a family fom project to family editor
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can't actually save out the family. However, you can start a new external family using the same family category as the in-place family and then open the project at the same time. Edit this in-place family and then select all the elements and cut and paste into the external family.
Thu, Sep 16, 2004 at 8:45:05 PM | RE: Saving a family fom project to family editor
liam
Yeh thanks that was what I originaly thought
Fri, Sep 17, 2004 at 6:39:40 PM | RE: Saving a family fom project to family editor
TAC
I'm not sure if this helps, but I just called Autodesk on this one... you go to the Settings menu, Options, click on the file tab called File Locations. I created a new Library Path to begin sharing families off the server and keep everything centralized.
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:31 PM
Family Editor: works... then doesn't!
Fri, Sep 2, 2005 at 5:23:05 PM
adding mass in family editor or in place family creation
Thu, Nov 23, 2006 at 9:52:52 AM
Door family showing one thing in Family Editor another when placed into project.
Mon, Aug 24, 2009 at 3:24:33 PM
Updating materials in family editor not updating project.
Thu, May 16, 2019 at 12:22:46 AM
Page generation time: 1.3455
