Forums >> Revit Building >> Technical Support >> FLOOR CUTTING OUT WALL MASS?
Mon, Jun 26, 2006 at 3:50:24 PM | FLOOR CUTTING OUT WALL MASS?
ICON
5 Stars: 3 Votes
I have a 2nd floor system in a section that doesn't remove the mass of the wall. How do I change this without redrawing it? Thanks in advance. Randy
Tue, Jun 27, 2006 at 2:31:39 AM | RE: FLOOR CUTTING OUT WALL MASS?
fazerneil
4 Stars: 5 Votes
edit floor on plan but dont change anything and then finish, you should get message asking if you want floor to extend into wall, answer yes. If this does not work then you have not set the floor to extend to wall core
Cutting irregular openings in curved walls
Sun, Apr 9, 2006 at 7:45:39 PM
Cutting a section through a mass
Sat, May 16, 2020 at 4:21:54 AM
cutting a hole in a massed floor/roof
Mon, May 11, 2009 at 7:07:00 AM
wall by face not being cut by void in mass
Wed, Jul 17, 2013 at 3:33:06 PM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
Page generation time: 1.5874
