Forums >> Revit Building >> Technical Support >> Windows in a Garage Door (Help!)
Mon, Jun 26, 2006 at 2:44:28 PM | Windows in a Garage Door (Help!)
Kalvin
I'm trying to edit the default overhead panel door in family editor to have windows cut into it. When I try to make an opening it just tells me that the opening is not cutting anything. Any help would be greatly appreciated. Thank You.
Tue, Jun 27, 2006 at 2:29:46 AM | RE: Windows in a Garage Door (Help!)
fazerneil
4 Stars: 5 Votes
could be a whole host of reasons. you really need to explain more about what you have actually done, the process followed
Tue, Jun 27, 2006 at 3:11:36 AM | RE: Windows in a Garage Door (Help!)
coreed
coreed Avatar
4 Stars: 16 Votes
just download one from the revit city library that already has openings to use as an example it may shed some light on your problem HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jun 27, 2006 at 8:58:43 AM | RE: Windows in a Garage Door (Help!)
TomDorner
4.5 Stars: 25 Votes
Chances are hte garage door family already has an "opening" which is a Revit object that cuts a wall. What you are trying to add are windows or lights to the garage door family which need to be modeled as Revit objects as the "opening" is what is cutting the wall for the entire garage door family. Tom
Tue, Jun 27, 2006 at 10:49:13 AM | RE: Windows in a Garage Door (Help!)
Kalvin
tomdimnm you hit the nail on the head thank you!
Garage door?
Wed, Dec 21, 2005 at 2:59:11 PM
Garage door openers
Wed, Feb 15, 2017 at 10:18:39 AM
Struggling to find a good wood garage door!!!
Mon, Apr 6, 2020 at 10:44:52 PM
Garage Door
Wed, Apr 6, 2005 at 3:45:22 PM
arched opening for overhead garage door
Fri, May 14, 2004 at 8:45:08 AM
Page generation time: 1.3376
