20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> slopped pad
2 Posts No Rating |
I have a 250' long building wiht a difference of 3' on its grade. I would like to place something like a slopped pad. Is there a way to do this?
I'm not 100% sure but when you make the pad is there a slope arrow just above the pad properties.
Macca Sunshine Coast QLD Australia |
take a look at this tutorial loacted in the Revitcity Tutorials
http://www.revitcity.com/tutorials/complex_slabs/
HTH
2 Posts No Rating |
Thanks for the replies so far.
Coreed,
The tutorial is very good and is a good way to handle an irregular floor. However, I need the ground below to "attach" to the bottom of my slab and cut through a toposurface similarly to what a pad does.
Puzzle,
There is no slope arrow.
I tried to set a work plane to match a sloped slab I created, but it seems that Revit cannot use (or I do not realize how to, in this case) the inclined plane of the slab as a work plane while in the pad command. (I can set the work plane to the face of the slab when I'm not in the pad sketch mode)
A sloped pad is something so much needed because, in most cases, slabs on grade are sloped!!
Topo slopped pad (parking lot/road) |
Mon, Aug 24, 2009 at 8:26:23 AM
SLOPPED FLOOR |
Wed, Jul 23, 2008 at 12:06:36 PM
SLOPPED BEAMS |
Thu, Jan 16, 2014 at 1:00:32 PM
Building Pad Problem |
Thu, Dec 20, 2012 at 3:51:08 PM
Roof condition |
Thu, Jan 14, 2010 at 12:37:17 PM
