18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Area Plans.....
20 Posts No Rating |
I have an area plan created from my Main floor plan. I put all of my room lines inside so that I could aquire the SQFT of each room. Now I want to have another area plan of the same floor plan so that I can get the total sqft of my building. I am working on a building equation. When I go to create another area plan of the same floor plan, it wont create another one. My guess is because one exists of the floor plan. So I then duplicated the area plan and deleted the room lines, but now it deleted the room lines in the first area plan.
How do I create another area plan of the same floor plan w/o the two effecting each other?
For the first option sounds like it would have been easier to create room tags and a room schedule and use the automatic areas from that rather than tracing all the walls.
As for the Area plans:
Area boundaries exist for each "area scheme". By duplicating the area plan they are both essentially for the same area scheme so a change in one will effect the other.
You can create new area schemes in your settings-->room and area settings-->Area Schemes
The defaults are Gross Building & Rentable, however you can have add new ones as you see fit.
Then to create a new area plan associated to one of these schemes go to view-->new-->Area Plan
HTH.
new Area Scheme question |
Tue, Jun 20, 2017 at 4:11:49 PM
Using Area Plans as Main Floor and Unit Layout plans |
Mon, Mar 29, 2021 at 1:59:33 PM
Area Plans for design options |
Fri, Jul 21, 2017 at 1:37:36 PM
area plans again? |
Wed, Sep 14, 2011 at 9:07:33 AM
Area Plans |
Wed, Nov 1, 2006 at 10:03:12 AM
