Forums >> Revit Building >> Technical Support >> Model Pattern Upside Down
Wed, Jun 21, 2006 at 9:13:25 PM | Model Pattern Upside Down
djlandreneau
I have used the paint tool to apply a cedar shake pattern to my walls. The problem is the pattern is being applied upside down. Any ideas? DJ
Wed, Jun 21, 2006 at 9:30:35 PM | RE: Model Pattern Upside Down
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
You should be able to select the pattern itself in your project view and rotate it 180 degrees. I think this only works for model patterns...or maybe it only works for drafting patterns. I don't remember, give it a try. :-)
Hiroshi Jacobs
Wed, Jun 21, 2006 at 9:37:06 PM | RE: Model Pattern Upside Down
djlandreneau
How do I select just the pattern? When I try I get the entire wall.
Wed, Jun 21, 2006 at 9:42:57 PM | RE: Model Pattern Upside Down
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
hover over one of the lines in the pattern and hit TAB until it is selected.
Wed, Jun 21, 2006 at 9:49:43 PM | RE: Model Pattern Upside Down
djlandreneau
Got it. Thank you very much.
Tue, Dec 18, 2007 at 4:30:50 PM | Model Pattern Upside Down
NKramer
4 Stars: 9 Votes
Does this work for patterns in wall types also?
Othewise does anybody know how to pick the origin or angle of a pattern?
I am trying to use a legend for general wall types. Typically we put line types in the wall but Revit only allows you to put hatch patterns in... So I uses a 45° hatch pattern for one and that works great. For the second wall type I tried using vertical lines but the lines are vertical to the screen not the object. Can you use a model pattern in a wall type? If so how? If not does anybody else have any sugestions for how they have worked with walls by legend?
Thanks
Nick
Fishscale Pattern Upside Down in Model
Tue, Jan 12, 2016 at 1:59:42 AM
Fill pattern upside down???
Thu, Jun 16, 2011 at 11:35:51 AM
Upside down wall pattern
Thu, Jul 13, 2006 at 8:31:15 AM
Upside down model
Fri, Nov 28, 2008 at 1:26:53 AM
model fill patterns
Fri, Sep 23, 2005 at 11:57:54 AM
Page generation time: 0.5831
