Forums >> Revit Building >> Technical Support >> Dimensions to Text
Wed, Sep 15, 2004 at 9:00:12 AM | Dimensions to Text
quiller
quiller Avatar
2.5 Stars: 3 Votes
Is it possible to create/change the actual dimensions to text? In other words have it say “Field Verify this wall” as apposed to “15’6” or whatever. This is possible in AutoCAD, but so far I’ve had no luck in Revit.
Wed, Sep 15, 2004 at 8:30:57 PM | RE: Dimensions to Text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could add a suffix or prefix to the dimension to add text, just click on the dimension (singular only) and click properties and add the desired text. There is no way i know of though to actually hide the dimension value, alternatively you can add text over the value with an opaque background...
Thu, Sep 16, 2004 at 8:13:52 AM | RE: Dimensions to Text
quiller
quiller Avatar
2.5 Stars: 3 Votes
Ok that works, but not quite well enought. Is it possible to change the Unit Format in the properties of a dimension to Rounding to the Nearest 1000'. So if I use this dimension on a room thats 14' wide I won't actually get a dimensions, and then if I "Supress 0 Feet" I'll be able to enter text in the suffix or prefix box and have it show up as the dimension????
Thu, Sep 16, 2004 at 9:17:09 AM | RE: Dimensions to Text
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
All I can say is give it a try! what we do is add a VIF suffix if the dimension is to be verified in field.
Hiroshi Jacobs
Adding Text Below Dimensions
Sat, Mar 3, 2007 at 10:55:04 AM
11
Rotating the text in dimensions
Tue, Feb 17, 2009 at 12:18:16 PM
Text width for dimensions...
Tue, Aug 7, 2007 at 7:55:42 AM
TEXT AND DIMENSIONS
Tue, Sep 28, 2004 at 12:49:38 AM
Temporary Dimensions text size
Fri, Feb 29, 2008 at 6:44:51 PM
Page generation time: 0.2239
