Forums >> Revit Building >> Technical Support >> Rollback option
Wed, Jun 21, 2006 at 1:49:06 PM | Rollback option
MrCampy
Can anyone help me with the rollback option and where it is located in the commands? I did it last week and now it has completely escaped my memory on how to set a drawing back two hours when one does not have the undo command available. Thanks.
Wed, Jun 21, 2006 at 2:59:02 PM | RE: Rollback option
rkitect
rkitect Avatar
4 Stars: 29 Votes
The only thing I can think of is to use the autosave file. Everytime you save (unless you changed the settings) it will put a file called 'Projectname.00#.rvt' in your project folder. Use one of those to get close enough. Other than that I'm not familiar with any rollback options. Sorry. Good luck!
Wed, Jun 21, 2006 at 6:08:34 PM | RE: Rollback option
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
On a worksetted file: File-->Backups..-->Pick backup directory then pick the file you want to roll back to and hit rollback.
Rollback
Thu, May 22, 2008 at 5:48:12 PM
Cannot make design option primary
Thu, Jan 6, 2011 at 2:08:04 PM
Design Option Issue - walls in 1 design option cutting thru a 2nd option
Thu, Oct 21, 2010 at 11:55:04 AM
Restoring from a backup file when filesharing
Thu, Jun 3, 2010 at 11:12:22 AM
Mysterious duplicate option sets
Wed, May 2, 2007 at 10:05:19 AM
Page generation time: 0.1414
