Forums >> Revit Building >> Tips & Tricks >> how to add elevations to door & window schedules
Tue, Jun 20, 2006 at 6:52:09 PM | how to add elevations to door & window schedules
alwin
Can anybody explain how to add the elevations of doors and windows to the schedules that are created within Revit, which only contains cells. Want the old style schedule showing elevations with maybe dimensions added. There are elevations in the families, van these be exported ?
Tue, Jun 20, 2006 at 7:32:04 PM | RE: how to add elevations to door & window schedules
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can create visual door and window schedules using the legend tool and legend components. Simply create a new legend, then place legend components of each of the types of windows you want (under the drafting tab) then dimension and annotate them as you require. We then use this in conjunction with a standard text schedule. HTH.
Tue, Oct 30, 2007 at 11:59:24 AM | how to add elevations to door & window schedules
NKramer
4 Stars: 9 Votes
When I add the window (schedule) Legend to a sheet the deatil number is a "?". HOw do I get that to show up as a detail number or do I just need to create a new view title family and get rid of it?
Window & Door Legends
Thu, Sep 10, 2015 at 12:41:54 AM
phasing in window & door schedules
Tue, Mar 16, 2010 at 3:27:39 PM
Wed, Aug 31, 2011 at 10:41:23 AM
Combining Door & Window Schedule; it WORKS!
Wed, Jan 20, 2016 at 10:15:28 AM
door & window elevation sheet
Tue, May 30, 2006 at 12:39:19 PM
Page generation time: 2.8983
