Forums >> Revit Building >> Technical Support >> small dimension box & tape measure dimension
Wed, Sep 15, 2004 at 4:59:17 AM | small dimension box & tape measure dimension
spot
my dimension boxes & tape measure dimensions are quite small & keep scale ratio as I zoom in ,don't get bigger,must be a scale setting somewhere! I've been looking but cannot find it. HELP.
Tue, Sep 28, 2004 at 1:21:38 AM | RE: small dimension box & tape measure dimension
papurajx
Change the 'View Scale' in the View properties..and try again..you might see them bigger.
Sat, Sep 20, 2008 at 5:05:53 PM | small dimension box & tape measure dimension
DAVID85027
I just fixed that problem with my program today!  You must go into your Revit.ini file.  Double-click on it and it should open in notebook.  Find the [graphics] line. (if there is not one, then type one in).  Underneath that line you need to type,"TempDimFontSizeInPoints=24"  The number refers to the size of the text.  24 works for me, but I have a 42" screen.  Maybe try 16 becuase Revit starts in 8.  Save the file and then restart Revit.
I actually have two revit,ini files and I had typed that in both.  That worked for me.
I have a question in return:
My tape mesure diminsions are set to 1/256 and are so all dimension attributes.  How can I change them to 1/16 or 1/8?  My project units are already set to 1/16 and it seems to do nothing for this problem.  I have been looking all over help and all over AUGI, Autodesk, RevitCity and such like and have not found a solution.  I would really help my tim in reducing fractions that we never deal with in real life. Thanks
Tape Measure Properties [ 1 2 ]
Thu, Aug 21, 2014 at 12:15:12 PM
18
Listening dimension display too small
Sun, Jan 31, 2010 at 6:43:41 AM
tape measure tool doesnt work in elevation
Wed, Jan 12, 2011 at 1:19:04 PM
Removing/editing single dimension in dimension string
Wed, Aug 26, 2009 at 7:12:02 AM
Model Dimension
Fri, Feb 13, 2009 at 9:54:13 AM
Page generation time: 0.2766
