Forums >> Revit Building >> Technical Support >> What the heck is going on?
Tue, Jun 20, 2006 at 5:06:11 PM | What the heck is going on?
sashk
In my site plan, with the shaded with edges mode sett, everything is cool. Once I draw in my property line, my model then turns into a wireframe. When I delete the property line, it goes back to a shaded with edges. What the hell is happeining here? Any ideas?
Tue, Jun 20, 2006 at 6:35:23 PM | RE: What the heck is going on?
vector23
vector23 Avatar
2 Stars: 16 Votes
sashk you've got a major situation going on with this apparently and i have no clue whatsoever... i just hope the hell i mean heck you find a solution.. PS i need to know too..
Tue, Jun 20, 2006 at 7:34:43 PM | RE: What the heck is going on?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Probably impossible to diagnose without the file, I'd suggest sending the file to support to have a look at and identify the issue. Ensure you are using the latest build. Try closing and rebooting and then attempt it again to see if it still occurs. I haven't heard of this issue before. HTH.
Wed, Jun 21, 2006 at 11:46:26 AM | RE: What the heck is going on?
sashk
So, got it figured out. I had my view range set so that the top was unlimited. I just set it to my site plan level and it cured the problem. Why? I have no idea. Any insight into this?
How the HECK does this work?
Wed, Oct 27, 2004 at 3:24:36 AM
How the heck can I get line styles to Families?
Mon, Apr 14, 2014 at 11:21:58 AM
Why the heck did this take 7 days?!
Mon, Apr 20, 2009 at 7:37:25 PM
extrusions
Wed, Jan 14, 2004 at 5:12:58 PM
Why no clouds
Thu, Dec 5, 2019 at 4:05:53 PM
Page generation time: 0.0305
