Forums >> Community >> The Studio >> Curtain wall sweeps?
Tue, Jun 20, 2006 at 12:40:07 PM | Curtain wall sweeps?
ghuhta
Does anyone know if you can add a sweep to a curtain wall? If so, how I'm having troubles adding a profile I've created to to a curtainwall. It only let's me add a mullion, but as the curtainwall turns the corner, the mullion won't fill. Leaving just a blank space. see attached file.
Sun, Jun 25, 2006 at 7:34:29 PM | RE: Curtain wall sweeps?
eldados
eldados Avatar
4.5 Stars: 8 Votes
i would do it as a mullion, if its turning the corner the mullion should follow...
Integrator
KarelCAD
Mon, Jun 26, 2006 at 10:22:15 AM | RE: Curtain wall sweeps?
ghuhta
Thanks! I found a solution already, took a while but it works.
Attaching sweeps to curtain walls
Fri, Feb 20, 2009 at 4:04:27 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Parapet wall sweeps not joining
Fri, Oct 25, 2013 at 3:00:32 PM
Arched Curtain Wall Arched Mullions
Wed, Jan 22, 2020 at 2:13:08 AM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Page generation time: 1.3467
