Forums >> Revit Building >> Technical Support >> a wall can have two thickness?
Wed, May 8, 2024 at 6:44:13 AM | a wall can have two thickness?
hihihi2057
Hi all,
I build a building exist but every walls has variant thickness
So i want have for exemple, start in 20cm and end 35cm
Is that possible in Revit?
I tried not to use so many wall in-intu
I use version 2022 and 2023
Wed, May 8, 2024 at 10:02:03 AM | a wall can have two thickness?
Revit does not have this ability.  You can model this by having a family, that is wall skin only (like drywall or plaster) and has a thickness, that you place on the proper angles to achieve the proper overall thickness at each end.
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:44 AM
Variable Thickness Wall?
Fri, Feb 10, 2017 at 6:09:58 PM
Revit 2013 - Window frame sweep with wall thickness
Wed, Nov 28, 2012 at 4:03:26 AM
diffrent wall thickness
Wed, Dec 6, 2006 at 3:23:00 AM
Page generation time: 1.2376
