Forums >> Community >> The Studio >> collums and walls
Tue, Jun 20, 2006 at 2:27:54 AM | collums and walls
riazadam
Can someone please tell me why if you insert a colloum and then draw a wall from that collum does the collum then take on the walls property ie when you view it in plan view you can not make out the difference between a collum and a wall. this is very confussing (sorry for the spelling)
Sun, Jun 25, 2006 at 7:35:33 PM | RE: collums and walls
eldados
eldados Avatar
4.5 Stars: 8 Votes
under the prefemces untick the automatic wall joint...
Integrator
KarelCAD
Sun, Jun 25, 2006 at 7:35:39 PM | RE: collums and walls
eldados
eldados Avatar
4.5 Stars: 8 Votes
under the prefences untick the automatic wall joint...
Integrator
KarelCAD
Sun, Jun 25, 2006 at 9:21:05 PM | RE: collums and walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The preference eldad refers to are located in the column family: Edit the column family-->Setting-->Family Category and Parameters-->There is an option here to have the column automatically join. Untick as required. HTH.
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Walls
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 4:58:35 PM
Page generation time: 0.2586
