Forums >> Revit Systems >> Technical Support >> Window sashes with different window numbers in the window schedule
Mon, Mar 18, 2024 at 7:24:40 PM | Window sashes with different window numbers in the window schedule
elizabethpetermathew
Hello,
Can I have multiple window numbers for the same window in a window schedule? For example, I have a triple window, but need to replace the glazing of the 2 side sashes as they are damaged and so would like to give a different number to the sashes, But the triple window is one revit family. How can I assign different values (is W1.1, W1.2 and W1.3) to the 3 sashes? Hope this question makes sense. Thank you in Advance.
Tue, Mar 19, 2024 at 11:49:53 AM | Window sashes with different window numbers in the window schedule
Look at my Feb 1 response in this thread: https://www.revitcity.com/forums.php?action=viewthread&thread_id=4456
Note, you have to edit the family to make this work.
Hope that helped.
Nested Revit Window vertical Alignment
Sun, Sep 30, 2012 at 9:56:56 AM
How to associate window to a room in window schedule
Fri, Oct 1, 2010 at 10:32:12 AM
Window Legends-showing nested components
Thu, Mar 20, 2008 at 4:20:36 PM
LOOKING THROUGH THE WINDOW, SCHEDULE
Sun, Dec 19, 2004 at 7:03:39 PM
Window's dimension don't show up in the window schedule
Fri, Aug 17, 2012 at 1:34:43 PM
Page generation time: 2.9544
