10 Users Online (8 Members):
Forums >> Revit Structure >> Tips & Tricks >> Rotating the view Port but not the text
Hi Gang,
i'm not sure if this has been covered yet.
i need to rotate the viewort to fit my plan on the sheet, but i dont want to rotate the text, is this possible?
TIA
Look at the similar threads below, your answer is there.
ok, that works for text, but what about slab and joint tags, column, pad footing and beam tags? when i rotate the plan 90 degrees, the slab and joint tages read upside down...
scaling text and dimension according to the scale of view |
Fri, Aug 29, 2008 at 10:26:28 AM
Rotating Family Text |
Wed, May 7, 2014 at 5:04:06 PM
View Rotation - Dimension text |
Thu, Jul 21, 2016 at 12:06:48 AM
keeping text horizontal while rotating view 90 degrees. |
Thu, Aug 13, 2009 at 7:09:55 AM
TEXT OVER SIZING; |
Tue, Apr 18, 2017 at 12:09:21 PM
