Forums >> Revit Building >> Technical Support >> How did this .pat Code number come about?
Thu, Jan 11, 2024 at 7:02:46 PM | How did this .pat Code number come about?
SquareEdge
I found on the internet a .pat file for a herringbone brick pattern.
The coding is as follows:
*AR-HBONE, Standard brick herringbone pattern @ 45 degrees
;%TYPE=MODEL
45,0,0,4,4,12,-4
135,2.828427125,2.828427125,4,-4,12,-4
It works fine. It's for a 4x12 brick (I think)
Could someone please tell me how the number "2.828427125" was arrived at? Mathmatically?
This seems to be for a brick of size 4x12. I would like to do a brick 3x10 but I can't do it until I get that number right (the number "2.828427125" which works for 4x12 doesn't work for 3x10)
Please advise.
Many thanks
Activation Code
Thu, Mar 10, 2011 at 3:25:54 PM
plumbing code
Tue, Jun 12, 2012 at 2:18:31 AM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
Stray Lines in custom Revit fill pattern
Fri, Jul 5, 2013 at 11:52:21 AM
.Pat Files - Creating new hatch (fill) patterns... with letters (Fire ratings)
Fri, Mar 19, 2010 at 11:58:57 AM
Page generation time: 1.0043
